Macro to Import Raw Data
Trying to create a Macro to Import .SND files, and Export as .WAV.
The .SND files must be imported as Raw Data, and I’ve been unsuccessful creating a Macro that will do that.
If I could get the files imported, then exporting as a .WAV is pretty straightforward.
The FFMPG extension does not import .SND Files.
Hoping someone has some insight.
Thanks in advance.
Unfortunately, there is no ImportRAW macro command. May I suggest turning to 3rd party tools, including online converters.
Thanks Jademan,
Since posting, I’d figured that’s the case and discovered I was able to do the conversions in Adobe Audition. Proprietary formats are always a problem…
Thanks for taking the time to respond.
Appreciated.
