Hi,
I’m wondering if there is the ability to create a shortcut with the command “rewind 2 seconds” + “play”.
This would be incredibly useful as I often end up doing this when editing podcasts to ensure that a cut isn’t noticeable.
Hi,
If you are cutting a bit out from a track, you can test the cut before doing it with “Cut Preview” (shortcut “C”).
The duration of Cut Preview can be customised in Preferences: https://manual.audacityteam.org/man/playback_preferences.html
