I frequently use a macro (with keyboard shortcut) to repair a glitch on the sample level and set a marker on the label track. It works as expected in v3.3.3, but no label is created with v3.4.2. The macro is a simple 2-liner:
Update: The problem first occurred after I had installed multiple versions of Audacity (into different subfolders of C:\programs\audacity), and using v3.4.2. If I started audacity in the v3.3.3 subfolder the macro worked as exepcted. Still I saw UI elements of 3.4 in the 3.3.3 window (beats & measures box in bottom left) - which made me uneasy about having multiple versions in parallel.
When I tried to continue my edits today (launching v3.3.3, then opening the project), the label wouldn’t even be created in this version any longer.
In a separate small test project however the macro worked fine, no matter what version.
So I uninstalled all the versions, rebooted and only installed v3.3.3, also resetting all preferences.
Now the label does get created, but only on a separate label track - not into the existing one (which I had renamed, FWIW). Closing the existing label track and importing it again doesn’t make a difference.
Is there a way to make my Audacity macro hit the correct - existing - label track instead of opening a new one?
EDIT: I just realized that the labels are not only created in a single new label-track (which wouldn’t be that bad), but each label gets written into yet another NEW label track! Which is now stopping me completly in my tracks …
here is another update: I tried installation on different systems (2x Win10, 1x Win11) an different versions of Audacity. I suspect that this odd behavior is due to some inconsistency in the installation.
Whenever I did what I think is a “clean” install (uninstall, manually delete C:\programs\audacity, “reset configuration” on new install), then the macro would always put each label on a new track - no matter what version I install. I tried v3.2.5, v3.3.3. With v3.4.2 on one installation I only get the first label created, subsequent invocations of the macro execute the “repair” command, but don’t create any labels at all …
Now, before I “ruin” the last working installation (v3.2.5 on Win11) I would like to know what locations I should look into for possibly cleaning up remainders of previoous installation.
Any help is appreciated!
