Can someone please help me. I am trying to batch convert files from FLAC to wav using batch export. I created a macro. The export worked. Although, I cannot open the files in any of my DAWs. The DAW gives me a message that the WAV files are unsupported. If i manually convert the WAV files one by one they work just fine in my DAW.
some DAWs have issues with 32-bit float WAVs, or some of the other exotic options Audacity has on offer like µLaw encoding. Others have issues with non-standard samplerates. You may want to run the files in question through MediaInfo to see what makes them special.
