Macro/automation for selecting periods of silence?
I spend a lot of time listening to recorded speech that I need to cut/trim, removing errors and extraneous recording takes.
Often there are longer or shorter pauses in the recorded track than I want to keep, so I select the periods of silence and then paste in the duration of room noise/silence. For example, if it had been three seconds long with some background noise, I select the section then paste in 1 second of room tone and everything plays great.
The only problem is that I end up doing this a lot, and I’m looking for a way to make my workflow more efficient so I’m not constantly mousing and pasting.
Is there a way to automate this, to have Audacity search for the next instance of silence (or near-silence, in this case) and select it?
I have attached an image to illustrate what I mean. In this case, the cursor is currently at a section where I just pasted room noise. The selection that is highlighted is where I am about to paste over with room noise. I would like to automate this selection of silence so I can merely approve or do the pasting in a more efficient manner.
Silence finder, finds but does not select silence.
Well, this guy thinks it’d be cool if it did.
I wonder how difficult it would be to code an add-on that could accomplish this? It’s definitely out of my skill range, but out of curiosity, I wonder-
Not hugely difficult, though Audacity can only have one selection at a time, so it probably wouldn’t help very much.
A better approach might be to use Sound Finder, then split the audio tracks at the label positions
(https://manual.audacityteam.org/man/edit_menu_labeled_audio.html#split)
You can then step from one audio clip to the next using the shortcuts “Alt + .” and “Alt + ,”
(https://manual.audacityteam.org/man/select_menu_clip_boundaries.html)
Thanks - I’ll look into that-
or
ffmpeg
(non-GUI option, command line, more programming/technically advanced)
ffmpeg -i input.wav -af silenceremove=1:0:-50dB output.wav
see
stack overflow - using ffmpeg with silencedetect to remove audio silence
stack overflow - using sox to detect silence
ffmpeg doc’s
“Removing” silences isn’t a problem with Audacity - just use the “Truncate Silence” effect (with appropriate settings) https://manual.audacityteam.org/man/truncate_silence.html
However, the original post isn’t asking to just remove silences.
