Greetings all. I have a frustrating issue: I have a simple macro that I would like to run on N mp3 files. I have tested it on an individual file and it appears to work. But when I select it in Macros pane and hit the Files button, nothing happens. There is no popup that allows me to navigate among folders and choose files to which I want to apply this macro.
Sometimes the Files button seems to do nothing at all. At other times it causes a spinning beachball. Sometimes the OK button seems to activate itself after I hit the Files button. But I never get a file chooser popup.
It’s quite mysterious and very frustrating, as I have over 20 mp3 files to which I want to apply identical processing – doing it by hand is going to be tedious (although tbf I have probably spent almost as much time trying to get the batch processing to work, as it would have taken to process them by hand – grrrr).
PS my version of Audacity is a bit older, 2.3.2 – is this a known bug in earlier versions? I am afraid to try to update Audacity because my OS is also a bit out of date, and this is a Hackintosh so an OS upgrade might be disastrous. I don’t want to break the mostly-working Audacity that is currently installed.
