https://manual.audacityteam.org/man/faq_installation_and_plug_ins.html#Mac
A Restart should not be necessary.
That’s it!
Writing that down—twice.
In an immaculately kept machine with no other errors, oddities, or damage, yes. However, for the rest of us…
Another note or two here. Are you using the Audacity Project Cloud Storage from audio.com - Muse Hub? Does Audacity still work OK if you lose your network connection (other than audio.com)?
Mine is Apple (up left) > System Preferences > Network. Note where the settings are and change it so all the balls are red.—no network connection. Is your microphone still OK and does Audacity record things?
I never use network storage. Mic does work without network connectivity. My uninformed hypothesis is that the Privacy & Security settings didn’t like the new version of Audacity until I wiped it and reinstalled it.
Got it. Thank you.
