Will there be an Audacity update coming soon for MAC OS Sonoma 14.1?
There are numerous incompatibility issues.
Audacity 3.4 Beta #1 is now available for testing purposes. Typically a release follows within a few weeks: Release Audacity 3.4.0 Beta 1 · audacity/audacity · GitHub
What specific issues are you having ?
The app crashes often.
I just updated to macOS 14.1, and Audacity crashes. It will work, but it does crash a lot. I can record and save, edit and save, but it crashes if I go to help > updates and it crashes on startup sometimes. I did an uninstall and reinstall of Audacity 4.3.3, and it still crashes.
You mean 3.4 beta? Thanks for the update.
As I am sure you both know, Audacity 3.4.0 was released a few days ago.
Yes, in my post I transposed the numbers, I am using 3.4 now.
