Mac OS 10.9.5
Dear Sir :
I had upgarde my Mac to OS X 10.9.5 version but seems it was not working with audavity version 2.0.1, please advise which audacity version can compatible to Mac OS X 10.9.5, thanks.
rgds
Raymond
The current Audacity version is 2.0.6. Please obtain it from Audacity ® | Download for Mac OS.
To avoid problems, please read this page carefully Installation: Do NOT run Audacity from the DMG!!!.
If you still need help, please say exactly what the problem is. “Not working” does not let us understand what the problem is.
Dear Gale :
thanks your advise but I would like to clarify whether only 2.0.6 can support Mac 10.9.5. Thanks
rgds
raymond
If you visit Audacity ® | Download for Mac OS as suggested you will see there
that 2.0.6 is for OS X 10.4 to 10.9.x.
So yes, 2.0.6 supports OS X 10.9.5.
If there is a problem with 2.0.6 on OS X 10.9.5, please describe the problem in full, so that we know what the problem is.
Dear Gale :
thanks a lot
