M4a read issue?
Hi Folks - please - v. 3.7.4 does not open .m4a audio files?
It flags such files as incorrect format - ???
Suggestions pleasse, thank you
Hi,
You don’t mention what your operating system is. Opening m4a files works fine on my Linux PC using version 3.7.4. Do you have FFMpeg installed? I think that might be needed to do what you are trying to do. One of the forum moderators might be able to say for sure.
In the meantime, this might help: Installing FFMpeg
Mark B
Thank you evilmrb - for the link - the issue is now resolved.
Cheers, Bebbspoke
Fantastic - you’re welcome.
