every time i hit play within my project, a loud buzzing/static noise will occur, and it’s different every time. this noise is only a split second long, and then playback continues like normal. i’ve tried it with and without my audio interface, same issue.
found something, it only occurs with the limiter in realtime effects.
I can’t reproduce this with the default Limiter settings.
What settings are you using?
I’m on Mac btw.
It only happens when using limiter in the realtime effects. Possibly try it in the master
