After upgrading to Audacity version 3.2.2, I lost my Audacity De-Clicker and Punch Paste Effects plugins. As well as some settings on external plugins. Is there a way to restore the plugins?
Thanks,
Brad
Thanks,
Brad
I don’t know why this is… Others may have some insight. In the meantime:
You can download the De-Clicker plugin here: Updated De-Clicker and new De-esser for speech
You can download the Punch Copy/Paste plugins here: Punch Copy/Paste
As all of these plugins are Nyquist plugins see here for installation instructions: Nyquist Plugin Installer - Audacity Manual
Thanks for the reply to my question of how to install the punch paste plug ins. Now, how do you find them to use them?
Thanks in advance!
Tari ![]()
Links to the files are contained at the end of the first post referenced above, where it says “Current Version: PunchPaste.ny”. Depending on your browser settings, you may have to right-click on the link, then select: Save Link As…
Have you located the downloaded files and used the Nyquist plug-in installer?
Have you tried to enable them using the Plug-in Manager?
– Bill
