Hello!
I have a 1 min long sequence i need to make into seamless loop, and that requires me to listen to the last 2 seconds and the first 2 seconds of the clip and make adjustments.
How to i make Audacity play from the cursor position and then loop back to the start of the track?
Shift+space seems to start the track from the beginning and not the cursor for some reason, very odd when the normal behaviour of Play is to play from the cursor. It is completely futile to have to wait 1 minute until it reaches the critical loop point…
I also can’t seem to make a selection that has the first bit and the last bit selected only, which would have been another way to do it.
Am I missing something very obvious?
Thank you
