If you go to the second page of this pdf: http://cambridgesound.com/wp-content/uploads/2013/02/Color-of-Noise.pdf you will find a sound graph. I want to create the “speech” sound on that graph. Is there a tool Audacity has that allows me to do this? I saw that if I click Generate–>Noise I have the option of white noise, brown noise, pink noise, but I don’t see anywhere where I can customize the noise.
If I can’t do this in Audacity, is there some other software that allows me to create custom noise?
I used Steve’s “SpectrumToEqCurve” experimental-plugin to analyse an actor speaking … speech-noise.xml (35.8 KB)
Then applied that EQ curve to white-noise to create speech-noise …
