Looking for additional EQ presets
Years ago, I found an xml file that contained a bunch of great Audacity EQ presets that I used for spoken word audio files.
I just upgraded to a new Mac Pro 2013, and in the process, forgot to back up that Application Support file where they lived.
I have downloaded the ones located here: http://wiki.audacityteam.org/wiki/EQCurvesDownload
But I’m looking for a more. Are there any links to Audacity presets that forum members know about?
Many thanks.
(I’m using Audacity 2.0.6, Yosemite 10.10.1)
How does Time Machine handle this? I did a MacBook Pro upgrade and told the machines to update themselves. They did it across significant OS versions and gave me a list of applications that failed.
Of course, if you were a complete slob on your old machine, that’s the environment that will follow you over …
Are you a transplant from Windows? There are several Mac tricks. It usually pays significantly to back up (copy) the whole /Users folder. That’s the parent directory to /Desktop, /Documents, /Movies, /Music, /Download, etc.
I don’t know of a handy list of Eq settings. Did you Google? You must have found that list the first time.
There are some other presets scattered through this topic https://forum.audacityteam.org/t/submit-your-eq-curves/14671/1 - but not explicitly for spoken word as I recall.
If you find a link to extra presets please post it here.
