Hello,
I’m new to the program and I was wondering if I am able to record a live output of effects to one of the output I pick from the list (like a voice changer)
Thanks!
Audacity does not apply effect in real time.
Whether or not Audacity can record while another application (such as a voice changer app) is using live input (essentially the same as recording), will depend on how that other app is using the sound system. It may be possible to record a standalone voice changer app by setting Audacity to record the sounds that are playing on the computer (see: http://manual.audacityteam.org/man/tutorial_recording_audio_playing_on_the_computer.html) but it’s not guaranteed.
Thank you for your reply, Steve, I’ve been looking everywhere for a program that can do real-time effects with the same options as this program… do you know of any other software that can do this functionality?
