Hi, I can’t get the LISP plugin to actually work in Audacity: It loads onto list of new plugins, I enable it and restart. It then doesn’t show up on effects and is under new plugins again. Any advice please? I’ve heard the LISP plugin is great and I really want to use it!
Thanks!
LISP is a programming language, so what LISP plug-in are you trying to use?
Hi DVDdoug,
Sorry, I probably should have said Lisp plugin, not LISP, my mistake…If I’m still not making sense (more than likely!) I mean the de-esser by Sleepy-Time…
Thanks! ![]()
Here is how to install VST plugins: FAQ:Installation, Startup and Plugins - Audacity Manual.
Be sure to point Audacity to the 32-bit version of the plugin. Audacity is a 32-bit host so cannot use the 64-bit version of the plugin.
Oh, you mean the VST plug-in that is called “Lisp”.
Instructions for installing VST plug-ins can be found in the manual here: FAQ:Installation, Startup and Plugins - Audacity Manual
(64-bit VST plug-ins are not currently supported. See also: FAQ:Installation, Startup and Plugins - Audacity Manual)
Oh boy, what a simple solution! I was trying to install the 64-bit version, doh!
Thanks guys, just downloaded and its enabled, woohoo! ![]()
