Line 6 UX2 interface problems w/audacity
Hi,
I could use some help getting started with Audacity 2.0.6. I have a Line 6 UX2 interface it has a mic input plus a intrument input the output is fed by USB to my laptop. I have configured the UX2 via control panel to output instrument/mic 1. When I monitor the UX2 via the vu input path I see and hear both the mic and instrument. However Audacity only shows the instrument (not the mic). If I change UX2 configuration to mic or instrument only audacity sees those signals? I’m sure I’m probably doing something basic wrong. Any help out there? Mark
ASIO, WDM and Mac OS X Drivers
Audacity doesn’t work with ASIO software. So you have to work with the WDM software drivers.
Make sure that Windows and Audacity are [u]set up for stereo recording[/u]. Sometimes Windows thinks every USB interface is a mono microphone.
