HI!
Info: OS: Win10 (latest updates including Anniv. update), Audacity 2.1.2 (just updated from 2.1.0)
Issue: I have a 2005 music CD with the heinous, discredited, and almost entirely forgotten Sony XCP DRM software.
What do I want to do: rip or convert the music on the CD into mp3 files.
What the XCP does: when you look in File Explorer, you do NOT see the music tracks, only the special CD player program and some other files. Audacity does NOT see the files (of course, Audacity > Import only goes to File Explorer so Catch-22 on that). The files can ONLY be played with the player on the CD disc.
NOTE: I do not have a problem with the XCP DRM causing any software, hardware or OS problems. I have checked those things out thoroughly, yes, I did learn where the XCP files are hidden and they are not on my computer.
I have heavily researched this on the web and know a lot about the whole XCP thing–how to avoid it, how to delete it (not easy and best not to do if it isn’t causing other problems) and much more. But not how to do this.
I have also tried Nero (crap, plus, even being careful during the install, it also installed Nero Tune-It or something which was even crappier), AIMP, and EAC.
And I did this hack: thoroughly colored the outside edge of the CD disc with black marking pen. Supposedly, this makes it readable but I think it only prevents the XCP from being installed on the computer, which can also be accomplished, more easily, by holding down the key after inserting the disc. Again, the XCP software installing/having been installed on my computer is not the problem.
Does anybody have a solution other than buying the music online (obviously without the XCP) or doing the “bad thing” (which I won’t even mention because I’m sure we all frown on that method of obtaining music and other copyrighted material)?
Thanks.
