I can’t launch audacity without MuseHub, when I click on audacity icone, I get an error message : “Point d’entrée de procédure introuvable…”
Yes I desinstalled and reinstakked Audacity
Did you click “Download without Muse Hub”? (I’ve never had Muse Hub.)
I did. I had to join audio.com (i did not want to) then… nothing
Check the hidden Audacity folder has been deleted …
https://support.audacityteam.org/troubleshooting/resetting-audacity
Then download audacity from here … Audacity ® | Downloads
I tried that too
and I had to join audio.com (i did not want to)
I did and then… nothing
Go to the front page of the Audacityteam website. There, you see the following:
The yellow download button downloads with Muse Hub - the much smaller link below it (where my arrow is pointing to) downloads without Muse Hub.
And no, nobody forces you to join anything - even if you download the Muse Hub Version…
You can just close that window. That’s all I did.
thank you for your kind answers.
