(my) filename: 4Plug-Ins _ Audacity notes2 1A
LAME MP3 and FFmpeg Plug-Ins
PROBLEM:
After installation of Lame mp3 and FFmpeg plug-ins
I exited Audacity and started it again.
The plug-ins were still found by Audacity BUT were NOT active in File > Export or File > Import
SYSTEM:
PC Computer: Win7 64b
Audacity: 2.2.2
LAME MP3: 3.99.3;
loc: C:\Program Files (x86)\Lame For Audacity\lame_enc.dll
FFmpeg: F(55.33.100),C(55.52.102),U(52.66.100)
loc: C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll
DOWNLOAD and INSTALL Lame mp3 and FFmpeg plug-ins:
Run Audacity > Edit > Preferences >
see: Pref window (no minimization possible)
Import/Export > Libraries
Mp3 Export Library > Download
connects to the internet; find and download the LAME MP3 exe file;
run the file and install (Accept default installation location)
FFmpeg Import/Export Library > Download
connects to the internet; find and download the FFmpeg exe file;
run the file and install (Accept default installation location).
Mp3 Export Library > Locate > (the default computer location should be displayed)
(after Accept default installation location, if the window says “not located”, then
Download, reinstall, re Locate).
FFmpeg Import/Export Library > Locate (the default computer location should be displayed)
Ok
