Use cases for multiple open projects:
*Combining the best of two takes.
*Using another clip as a noise source for the noise reduction effect.
Labels: needed to annotate notes and sections.
Problem: switching to another open project,
the creation or editing of a label is broken.
Create a label, or click on any existing label to edit,
then any letter typed is interpreted as a command to Audacity,
not as a letter to add to the label.
Temporary fix: switch to another Application, then back again.
Doesn’t matter which app. This always works. Unpleasant though.
A real fix would be appreciated. Still present in 3.5.1.
(The OS is OSX).
