Is there any possibility to set the project-rate with keyboard-commands? I have to edit many wav files and in the end I need 16000 Hz (telephone answering machine). It would be grea, if I could do that either in batch-mode or in a makro.
Also I am looking for a possiibility to use the envelope tool in batch mode. I would like to set the tool to maximum level in all the file, so I don’t use it in small parts to set something special…
It would be so nice, if I could find some help here (that would save much time, I don’t like the mouse - click, click…)
Thank you for answering.
That’s tricky because Envelopes are primarily designed for mouse use, but it is possible to set envelope points. see: https://alphamanual.audacityteam.org/man/Extra_Menu:_Scriptables_I#set_envelope
