I use the home and end keybindings to navigate tracks.
Audacity 4 doesn’t give me those options.
Please return them.
Please return them.
Is this the same as the “rewind to start” and “rewind to end” buttons in the transport tool bar? If so, you can go to Preferences > Shortcuts, search for “Rewind” and set the keybindings you want for those.
It helps to know the names Audacity uses for them!
I found it shortly after I submitted my post… of course.
thanks man!
