I have two WAV files, A and B, and I want to join them by appending B after A.
How do I go about it?
Using Audacity 3.0.2 and Windows 10 64bit.
Thanks steve, very clear instruction.
In older Audacity versions, I used to do it by copying file B and pasting it at the end of file A. That was intuitive, but I couldn’t get it to work this time.
Also, there was a tool for smoothing the transition. I couldn’t find that either.
That should still work, though it is not necessary for both A and B to be on the same track, they just need to be one after the other.
Having said that …
That is still available. In fact there are several ways to do it. Probably the easiest is if both A and B are on the same track (despite what I wrote above).
After importing A and B:
(The Cut / Paste commands are also available in the “Edit” menu, but the keyboard shortcuts are quicker)
Then, to smooth (“crossfade”) the transition from A to B, use the “Crossfade Clips” effect (See: Crossfade Clips - Audacity Manual)
Yes, got that to work too, thanks.
Query fully resolved.
