When I imported a CD into iTunes, it split a song in two as if they were separately laid down. I want to join them back together but don’t know how. Can someone help me with this? Thanks
iTunes will do that if the CD has two separate sound tracks, such as two separate songs.
Drag the two tracks out of iTunes and import them both into Audacity. They will appear one above the other and play at the same time.
This is where it gets fuzzy. It’s one of the Tracks > Align Tracks tools. If you pick the right one, it will slide the second track over so it starts after the first track ends.
Align with Selection End…???
File > Export. Audacity will make one sound file from both tracks.
