I wanted to join the several movements of a Bach cantata, recorded separately, into a continuous recording of the whole cantata. I loaded all the tracks into Audacity, clicked on Tracks > Align tracks > Align end to end. But the tracks were superimposed instead of following one another. What should I do?
Thank you for that suggestion. I have not yet had time to try it, but shall report on the outcome as soon as I can. But in the meantime: why,whydoes the method I described above not work? Surely that is what it is intended for, and it is the method described in online posts (not Audacity posts, though).
Too dilatory of me! I decided after all to try it at once.The answer is that Tracks > Mix > Mix and Render does what it says on the tin: it mixes the tracks! Just as the apparently authorized method I described i my first post does. So I am still at a loss as far as joining the tracks end-to-end is concerned. I continue to be grateful in anticipation of suggestions and instructions.
Thank you, Steve. This is beginning to help. But I took your advice and tried it, and the resulting file (which should have got all 8 tracks on it end to end) has the first track, correctly followed by the beginning of the second, but stops a few seconds into that second track; and the rest of that track and tracks 3 to 8 are not there at all. Could it be that there is a limit on the total duration? Once more, further advice will be most gratefully received.
In answer to Steve, I mean that the start of the 2nd track is correctly joined onto the end of the 1st; the 2nd track then stops after a few seconds, and none of the other tracks (3 — 8) is there at all.
I have now discovered that if I only load tracks 1 and 2 into Audacity and then use the same procedure (including selecting all as specified by you), both 1. and 2., correctly joined, are created in full. Do I need to now join 3. on in the same way, then 4., etc., one at a time?
In answer to Jademan: Thank you, I shall try that.
And now — that’s brilliant, Jademan! It worked smoothly and perfectly! Thank you very much indeed. I don’t think any of this is in the Audacity Manual, is it? It really ought to be there. To be able to join tracks together end to end must be a common requirement, surely, and should be described in the Manual?
