Hello Everybody,
Please, how can I join multiple files into just one big file?
Best regards,
Rosa
Hello Everybody,
Best regards,
Rosa
Hi,
You can use the Time Shift Tool to move tracks around.
Import a file to a track then import another to a second track. Use the Time Shift Tool to drag the second track to the end of the first. You can then delete the now empty second track, Zoom the timeline outwards and import another file then repeat the process.
Regards,
Neil
Note that if this is for chapters in an audio book, it may be better to keep the tracks separate - audio book publishers usually insist on one chapter only in each file.
