iZotope RX
Does anyone use iZotope RX in their work flow? I bought this tool many years ago and have struggled to use it in my audiobook workflow. I (like many) have a home studio and do have imperfections that the ACX Audiobook Mastering macro does not fix. These imperfections include clicks and pink noise that, the latter of which I now believe comes mainly from the house next door’s outdoor AC unit.
Do other users on this forum run their audio through iZotope RX’s Voice De-Noise or Repair Assistant in an efficient way that does actually polish their audio immediately before or after running the ACX Audiobook Mastering macro?
Jamie
Before you complain to the neighbours …
Pink noise is created by complex systems which can exist in many states, e.g. surf, rain, electrons, neurons …https://en.wikipedia.org/wiki/Pink_noise#Occurrence
Next door’s outdoor AC unit could contribute noise, but it won’t have the characteristic pink frequency-distribution.
The self-noise inherent in your (& all) electronics would be the prime-suspect for pink noise.
