I have been trying to get Nectar 3 elements to work with audacity 3.0.x with no luck. I am able to see the plugin in the add/remove plugins window. When I enable it, it does not show in the effects window. If I go back to the add/remove window, it still says new, not enabled. Has anyone had any luck getting this to work in Audacity?
Does it run “stand alone”? I believe some Izotope products can be run as a stand-alone application instead of as a plug-in.
It does NOT “officially support” Audacity so it MAY work in Audacity:
Supported hosts:
Logic Pro, Ableton Live 9.7 - 11, Pro Tools 2021, Cubase 10.5 - 11, FL Studio 20, Studio One 5, Reason 11, REAPER 6, Bitwig Studio 3.
