I am using a MaciMini M4Pro with MacOS 27.2.1 . I updgraded to Audacity 4.0 upon release and was able to import by Audacity 3 files with no issues. I use this to cut voiceover tracks for our church using music with a voiceover. In the past I was able to open the last week’s file, remove the voiceover track, record and new one, then save as with a new file name. This week I opened Audacity and while it would find my file, it would open but no let me save or save as. I kept getting errors about a disk full (which is not over 50GB available and this is only a 90 sec file) and connection to a library. Following a suggestion, I removed the app and renamed the library to Audacity_old and then reloaded and restarted Audacity. I was able to access my old saved file, and edit. However saving the file returns the same save error messagess? What is missing here? Also I have never been able to save to my OneDrive account or export to it. The export crashes. I can save locally then upload to the OneDrive Account. Is it due to path’s from the old files or other settings? I am not able to see anything in preferences that points to an issue.
Oh and I uploaded and am using 4.02.
