I noticed in Audacity there was a new option to isolate and remove voices. Can you also create an AI update to isolate and remove sound effects, individual musical instruments, as well as individual voices and give the user the ability to have these isolations appear in the player as individual separate tracks, like a separate tab below the track they were removed from?
Also, I don’t understand the current isolate and remove voices setting, and it no matter what I set it on it either distorted the music or it didn’t remove the voices or lyrics whatsoever. On top of that, when I chose to isolate the voices, it kept everything on the exact same audio track tab and all it did was distort the audio. Can you create an update that not only fixes these issues but also simplifies the settings so you don’t have to set either of the kHz and the strength setting just isolates each of the voices as a separate audio track tab even if the is more than one voice playing simultaneously?
