Isolate or extract bass. Audacity 3.0.0
Hello there!
I am new to Audacity, just downloaded it. How can I isolate/extract bass from a song using Audacity?
Thanks in advanced for you help!
A high-pass or low-pass filter (Effect → Classic Filters) can remove the bass frequencies (high-pass) or remove everything but the bass (low-pass). You can’t isolate bass guitar from any other low frequency instruments.
Which frequency shall I use? What is about the Roll-off?
That’s the steepness of the filter. See: Low-Pass Filter - Audacity Manual
The higher the number, the steeper the cut-off.
Start at around 200 Hz. Use the “Preview” button to try different values.
Audacity can’t separate voices, instruments or sound from a mixed performance.
Instruments are mixtures of different tones, overtones, and harmonics. Separating bass isn’t going to give you a bass guitar or bass violin. It’s going to give you a wet towel hitting the floor or thunder.
That depends on what you’re trying to accomplish. You just have to experiment… Maybe start with 100Hz. There is no “definition” of where bass starts. The standard home theater subwoofer-crossover is 80Hz. A bass guitar has a pretty-wide range and it goes higher into the mid-range frequencies.
