Hello everyone, I have a question: is there a way to multi-select in the track?
Example, if we want to multi select some file in a folder to delete we use CTRL+click with left, but can we apply an effect at some time intervals together?
I hope that I had correctly explained my question, thanks.
Thanks for the answer, I didn’t know the Limiter: it is easy and helpful: but using it will have some effects on the song quality? Does it lose quality or had some modify?
