Is there any way to speed or slow down a song in semitones?
I use the pitch and tempo effect, and I really like it. But the thing is, I can’t really find a way to slow or speed a song in semitones.
The easiest way may be to open the Change Pitch effect and when you enter the number if semitones it will show the percentage which you can then enter into the Change Speed effect..
