I think audacity is one heck of a program and i’ve been using it for several years without a hitch. With smartphones all the rage, will Audacity make a Mobile App for Iphone or Android? Would the software be so large that it would totally freak out the phone? Just a thought…so get cracking! ![]()
We’re struggling to bring out Audacity Version 2 on all three computer platforms, so I wouldn’t be shocked to find no plans at all to bring out yet another platform. Unless you want to help us write it. Can you program?
I wish. Sorry, just a user…but not an abuser. you guys rock. Thanks for your knowledge and product.
Audacity has been developed using the wxWidgets toolkit library. wxWidgets provides the graphical interface for the (mostly) C+ code. Android does not support wxWidgets so there is no possibility of Audacity being ported to Android in the foreseeable future.
I would pay $5 for the app and of course allt he previous work done on it.
If at some point in the future Android is able to support the wxWidgets library then there would be a possibility of developing an Android version, but until such time it is not possible.
If one knew someone with unlimited $, would you suggest they approach Audacity developers or Android developers to finance the way forward to the Audacity on Android promise-land?
9 years later …
Android still does not support wxWidgets, but Audacity has progressed significantly. It’s still unlikely that Audacity as we know it will be ported to Android / iOS - the user interface would have to change a lot to be usable on a small touch screen, the large amount of data (32-bit float PCM format) is likely to still be a problem, many of the libraries required by Audacity are not supported by Android / iOS, … and many other reasons. However, there’s a possibility that Audacity may be converted to use Qt in place of wxWidgets, and Qt does support Android / iOS, so there’s a possibility that a “light” version of Audacity may eventually be developed for Android / iOS.
Me too. £5 [now more like £15]
I use my phone but once the apple
/droid wars started I had previously had an Samsung Omnia smartphone and then SGS [1].
I think I had to use FLS but once I found myself immersed in the android dev scene over on XDA rooting and trying different ROMS at that time it was mostly DARKY’S & then AOKP on the note 4 .
I realised how some people are born gifted with coding skills just like [use whoever/whatever] sportsMEN. No woke BS here. ![]()
I tried my hardest to get to grips with C+ [the easiest & made a little headway but it was all a lot harder than I thought & decided that the next best thing would be to test out the pre builds before they were greenlit.
Thankfully I am knowledgeable not to worry about bricking my phone and if something went wrong I could just fix it. But it was hard work learning how to do this compared to a 12yr old that could write code but not work out how to bend a football [like Beckham
No-one is born with coding skills. Coding skills are learned by “people”. Successful software developers are usually “awake”, because writing software requires the ability to think critically.
