Is there a way to create a macro that zooms vertically?
Every time I need to enlarge the waveform, I have to go with the mouse to the left vertical bar and press or use the pointer and shift. I would be useful to have some key combinations available to simply enlarge the audio portion more easily like we can do on the horizontal axis.
If you create a macro with the “Set Track Visuals” (as shown in my previous post), then it will apply the specified vertical zoom to the selected track(s) when you run the macro.
You could create one macro for each zoom level that you require.
