Is there a reason why Audacity earrapes the **** outof me overtime when I'm using 5+ realtime plugins..?
Had this bug for the past twoish years… Seems like a “common issue” with no real solutions, is a shift to reaper the best option for me? thx :slight_smile:
what do you mean by that exactly? Does it begin stuttering? does it get louder? With what plugins does it happen? Does it go away if you disable a plugin? Or restart audacity?
