Is there a plugin that automatically envelopes?
Wow it seems like such a never ending learning curve. It’s funny how I can edit something and then listen to it at a later time and wonder ‘what the heck was I thinking’.
My dilemma is cheap recording equipment and possibly undue tenacity to think I can edit it out!
Here I go again: Yes, high pass filter but not too much! Currently I’m thinking slightly below the middle peaks, as recorded with a dynamic mic*.
So only needing high pass on my DR-05 recordings where I did not use an extension (dynamic mic), but used the built-in condensors which pick up a ton of low end.
Also, the DR’ has built in low cut which I will probably set to 80 hertz next time, if I record w/o the dynamic mic. It cuts at 40, 80, or 120 and 80 is usually around where I need the high pass, … hard lesson.
Other than that, to bring things down further in other areas I can use what ever, however, with the low end problem being THE big PROBLEM hopefully solved.
  • “Line Up” is my song that came out good! And when I looked back on my notes and looked at the plot spectrums it was with the dynamic mic and little editing was needed, just basically manually lowering loud areas with GCom compressor and Audacity Limiter, not even touching parts of the song. And that’s the way I like it, as natural as possible.
Thanks,
Reverend Black Dog
https://www.reverbnation.com/revblackdog
-my newest edits are on top.
There will be neural adaptation when listening to a track on repeat.
So returning to it after a break, (during which the adaptation wears-off), it will sound different.
Spectrograms don’t suffer from that.
FYI Trebor /and all, one of your links (jeroenbreebaart.com) I think? led me to (JB) Barricade Pro a “Multi-factor limiter VST plug-in” great tool! Big help, a limiter like no other and I’d say this solves the original question of this thread “Is there a plugin that automatically envelopes?” Yes, the (JB) Barricade Pro. Thanks.
Reverend Black Dog
-My newest edits are on top. Rough live lo-fi recordings. My current album “Fugitive Justice”/edits were recorded with a dynamic mic so there is no low end problem. Edits are mainly consisting of simple limiting (e.g., Barricade Pro) to bring peaks down and volume up avoiding the harshness of compression and high pass filter and even Noise Reduction.
“Barricade Pro” is in the zip bundle I downloaded from here …
https ://web.archive.org/web/20130329211641/www.jeroenbreebaart.com/audio_vst_jb.htm
But I haven’t tried it myself.
