Hi
is there a plot spectrum without time limit?
the limit is 237.8 seconds
thanks
Hi
thanks
No. If there was, the time limit would then become waiting for the plot to draw on your screen.
Hi Gale
and to have the frequency analisys of the entire audio ,for example a song ,should i use a vst effect?
i don’t know any that can scan an entire song they are realtime mostly
thanks Gale
We can’t do the search for you. But you can view the whole material in Spectrogram View.
Hi Gale
thanks for your response and the link
my english is poor
but when i tried to Analyze->plot spectrum ->i got this message
“Spectrogram” rather than “spectrum” , see …
hi
yes i know the different between the names
but i would like to know if i can edit and change the preference for plot spectrum , i need it too to check and compare recording with my external dacs
and about
there are other program like waveshop or Wavosaur that can do it , they are no slow and without limit
audacity is my favorite program , can’t understand why there is the limit and why it has to be slow
thanks
It’s not a setting, so you would need to modify the source code and recompile.
Is it not enough to compare a couple of minutes?
If you really need an average over more than 3 minutes, you could analyze the recording in sections, export the results, then use Excel or some other program to average the results.
