Hi, I have a song I like, but there is a particular sound that’s used throughout the song that I find grating and makes it hard for me to listen to. Is there a way I can remove this sound, or at least modify it to make it less uncomfortable? I’ve only used audacity to trim and fade songs so I don’t know if something like this is feasible.
The Envelope Tool can fade-down or fade-up a selection. And that’s the “trick”… To fade so there are no sudden jumps in volume, and to keep the end-points unaffected.
It looks like the sound shows up pretty clearly on the spectrogram, and spectral delete can remove it without altering the song too much. Thanks, I think I can do this!
