I’ve done a search of the forums for this question but results aren’t clear to me.
The Linux Studio Plugins Project provides some useful plugins in various formats of which I’ve concluded that the VST is the most easily recognised by Audacity (just drop the files into a user’s .vst directory and they are picked-up by the Add/Remove Plug-ins… feature).
The stated requirement for using the VST plugins is that the host software, i.e. Audacity, must be linuxVST 2.4 compatible. Does Audacity qualify in this respect?
about linux native vsts (there is much less choice vs windows) ( i couldnt get lv2, vst3(unsupported) or vamp to work)
/usr/lib/vst
or at
.vst
paths, could there be custom paths added?
but it might help if the part of audacity that loads or handles the vst
is a separate process (maybe one for 32 and 64-bit’s), maybe opens up possibility of native 32-bit on 64-bit and vice versa
may make it easier for the 32-bit windows port to work with 64-bit vst’s…)
but LinVst ( i don’t know the people who make it )
allows 32-bit VST’s to work on 64-bit linux
also for ocenaudio (windows) files such as
ocenvst32.exe
ocenvst64.exe
seem to
hint on vst loading architecture, but the linux version of ocenaudio does not work with LinVst
