I was attempting to Amplify one clip and the following message popped up:
Internal error at D:\a\audacity\audacity\libraries\lib-wave-track WaveClip.cpp line 174.
Please inform the Audacity team at https://forum.audacityteam.org/.
OK
So here I am, informing you.
I am using Firefox v 112 on Windows 11, Audacity 3.3.0 and I don’t have a drive D:
I got around the problem by copying the clip to a different Audacity window, processing it there, and copying back to replace the original.
The afore mentioned ticket contains all of the information that has been tracked about this problem - including that as far as is known it only occurs for one individual and may be limited to the 3.3.0 release. If this (or similar) error is happening for you, please update the ticket directly and provide a screenshot if you can of the error.
