hello i can’t quit audacity because it says that there is an error on line 75, so i can’t update my mac, please i need help
To quit an application on macOS which does not want to be ended, you can use the keys
Command + Option + Escape pressed at the same time. Then a dialog pops up with all open application. You can force-quit the reluctant application by clicking it once with your mouse and then click the button “quit immediately” (in German: “sofort beenden”).
After that, you can download another version and onstall it. Before that, I’d delete everything in the folder “~/Library/Application Support/audacity”. The sign ~ denotes your user folder.
thank you very much
