Hi,
I’m installing the dblue crusher VST plugin into Audacity. However, when I click Allow in the add/remove plugins menu, it says “Unable to load library” or something similar. The path where I put the DLL file is C:\Program Files\Audacity\Plug-Ins
Am I doing something wrong here?
Audacity version: 3.1.3
By default you will be served-up the 64-bit version of Audacity 3.x.x
If you want the the 32-bit version you have to seek it out:
it’s on this page … https://www.audacityteam.org/download/windows/
[ 32-bit version will not run 64-bit plugins, and vice versa]
Yes it will, but I use the zip version to keep it completely separate from the 64-bit version.
Unzip it into a folder, then launch it by double-clicking on the “Audacity.exe” icon in the folder.
