How do i install Gsnap on Linux Ubuntu?
I don’t find the plug-in directory on linux for audacity.
Please help me.
Please help me.
As far as I’m aware, GSnap is Windows only.
Go to https://www.gvst.co.uk/gsnap.htm?pageview=selectos and get the GSnap version matching your OS - most likely “Linux/GSnap (for 64-bit VST hosts)” is the correct one.
sudo cp GSnap.so /usr/local/lib/vst/. from the .zip file (create the subdirectory with sudo mkdir /usr/local/lib/vst if necessary).
sudo chmod ugo-x GSnap.so to remove the superfluous executable flag from the file.
(Re)Start Audacity, Open Tools/Add/Remove Plugins, locate the GSnap plugin and activate it.
