Move the cursor where you want to insert, then split the track.
Record the new audio on a separate track,
then use time-shift-tool to move the clips so it sounds as if it was done in one take.
Should I reload the Edit Master track and make the split there?
Do I make the new 3 word phrase on a new track … and how do I select that track?
Once i have the two tracks as you’ve shown, how do I move the phrase from the lower track to the upper one and then slide the split back together (thus adding a couple of seconds of recording time)?
Once I’ve recorded the 3-word phrase on the new track, how do I fit that into the upper track … in other words, do I need to somehow extend a portion of the upper track to make room the insertion. Since the phrase is ‘later that evening’ I probably need a second or two of air time at both ends of the insertion.
So I guess my question is … how do I make room on the upper track for the insertion? I played around with splitting the track but that didn’t seem to answer my question because I couldn’t expand the track to allow for the insertion.
You can adjust (timeshift) the position of three clips, (before, insert, after), anytime you like before rendering.
You can “close the gap” after you’ve recorded the “later that evening” phrase.
Normally* you don’t do that. The typical way is to mix and render (amalgamate) all the tracks.
[ * you candrag clips up & down onto other tracks if you want, but that makes an undetectable repair more difficult IMO ].
If you want an undetectable repair, then yes you’ll have to process the inserted phrase the same as the master.
it’s really helpful, but I have another question, if i finished recording, then have to do a lot insertion. do i have to record the every new insertion on a new track? sorry, I’m new to audacity.
