I found this plugin, it changes the tempo of a selection to lengthen or shorten it. Then I did some modification, removing the input box, and fixing the target length to original_length + 0.1, it works in Nyquist Prompt, but when I tried to install it, there was an compatibility issue. How can I solve this? Thanks a lot for any help.
Code
;nyquist plug-in
;version 5
;type tool
;name "Increase Silence Duration"
;; Original project: https://audionyq.com/stretching-audio-to-length/
;; Adjusts the length of a track to a specified length
(aud-import-commands)
(defun get-selected-length ()
(let ((start (get '*selection* 'start))
(end (get '*selection* 'end)))
(- end start)))
(defun change-tempo ()
(let ((trk-len (get-selected-length)))
(setf TARGET-LEN (+ trk-len 0.1))
(if (<= TARGET-LEN 0)
(throw 'err "Error.\nTarget length too short."))
(setf percent (* 100 (/ (- trk-len TARGET-LEN) TARGET-LEN)))
(aud-ChangeTempo :percentage percent))
(change-tempo)
Error message
