Importing labels with selected frequencies
hello, i am currently using some audio files to do a soundscape of a marine ecosystem. when creating labels i can save them and extract them with both lenght of time and the selected spectral frequencies (box on the spectrogram), but when importing them from the saved labels on my computer, i can just see the lenght of time of the label and i lose the “box” on the spectrogram. is there a way to save and import back the labels with also the selected frequencies?
note: i have already modified the extraction to “extended” and not “standard”, but this seems to only work on the extracion…
thank you, greetings from Uni Bicocca :slight_smile:
Please post a screen shot of what it looks like before you export and what it looks like when you import again. I was not aware that you could put text boxes on the spectrogram.
