Hi
New to Audacity so giving alot of info.
I am trying to import an dictaphone MP3 file that is corrupt. (the file doesn’t open in win media player, adobe audition etc)
The file was deleted/moved from a memory stick and i recovered it using Recuva recovery software.
The file format is MP3 sound format and the size is 99MB - it has no length when displayed in Windows explorer.
When it imports into Audacity its blank, empty i.e. no sound/noise, wavelengths.
Also, the dictaphone file should be over an hour long but is imported with less time e.g. 40 min.
I’ve tried importing the file (not recognised), then importing the raw data - with the raw data i tried a few settings but didn’t know the exact settings to use e.g. Encoding, Byte order.
I’m using Audacity 2.0.5. - the exe, on Windows Vista.
In Audacity both the corrupt and a working dictaphone MP3 file give the following properties:
MME, Speakers, Microphone, 2 (stereo) input channels, 44100 Hz, 32-bit float.
FYI:
A working dictaphone MP3 file in VLC player gives the following Codec properties.
Codec: MPEG Audio layer 1/2/3 (mpga)
Channels: Stereo
Sample rate: 44100 Hz
Bitrate: 192kb/s.
A working dictaphone MP3 file in Abobe Audition gives the following properties.
Bit Depth: 32 (float)
Source: MP3 192 Kbps CBR
My questions are:
- What raw data settings do i use?
- If these raw settings do not work what else can i do?
Regards
Donal.
